HKZ Bob's Avatar
CASE Savers Installation homemade
I like to do my case saver installation at home, so I have some questions before I start.
I will use my box colum drill & have it centered over the original stud.
For an thread of M14x2 I need a blind hole of 11,4 mm.
I am not intending to use a drill or a milling cutter. I would like to use a broach or reamer to widening the bore to keeo it in center.
Once the bore is available I am intending to use a three stage tap
which I will insert into the drill ckuck to have it align propperly.
Any comments or suggestions. Thanks for good advices.
Bob
Old 08-23-2007, 03:43 AM
