-   -   Anyone used Weltmeister Hydra-stops. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/365463-anyone-used-weltmeister-hydra-stops.html)
madpcar 09-04-2007 06:51 PM
I have seen these advertised - has anyone used them - what do they actually do ?:confused:
al lkosmal 09-05-2007 06:20 AM
They are simple spacers that clamp onto the tensioner shaft and act as a mechanical stop to prevent total tensioner collapse if a tensioner fails.
cstreit 09-05-2007 07:25 AM
Plenty in use and they do work. Pelican carries them.
cgarr 09-05-2007 07:33 AM
Is there anyway to tell when they work? Could you have a failed tensioner and never know it? I did the internal mod to mine
madpcar 09-06-2007 09:38 PM
cgarr,
Whats the internal mod you did ?
cgarr 09-07-2007 10:02 AM
Here is where I found the info:
http://forums.pelicanparts.com/showthread.php?s=&threadid=199819&perpage=20&pagen umber=3
t930928 09-08-2007 07:41 PM
They worked for me.
Back before they invented the tensioner upgrade I used them and they saved my engine on a 77 930. When the tensioner failed you could hear a noticable chain noise, however the hydra stops prevented total collapse of the tensioner. Really cheap insurance if running the original tensioners.
techweenie 09-08-2007 08:00 PM
+1
hcoles 09-11-2007 08:14 AM
I made and installed the "internal" type also. I call them "Jerry Woods slugs". Turns out there is a bushing at Orchard Supply I think it is a 5/8" bushing made from brass. The OD of these fits perfect in the ID of the tensioner. Cut off a piece and sand down. I went with about a 1.5mm clearance. So far so good.
madpcar 09-11-2007 02:57 PM
Great info guy's. Thanks for the help
