Mad Aussie Porsche nut
madpcar's Avatar
Anyone used Weltmeister Hydra-stops.
I have seen these advertised - has anyone used them - what do they actually do ?
Old 09-04-2007, 06:51 PM
al lkosmal's Avatar
They are simple spacers that clamp onto the tensioner shaft and act as a mechanical stop to prevent total tensioner collapse if a tensioner fails.
RGruppe #669
http://www.x-faktory.com/
Old 09-05-2007, 06:20 AM
Super Moderator
cstreit's Avatar
Plenty in use and they do work. Pelican carries them.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-05-2007, 07:25 AM
abit off center
cgarr's Avatar
Is there anyway to tell when they work? Could you have a failed tensioner and never know it? I did the internal mod to mine
______________________
Craig
G2Performance
Old 09-05-2007, 07:33 AM
madpcar's Avatar
cgarr,
Whats the internal mod you did ?
Old 09-06-2007, 09:38 PM
abit off center
cgarr's Avatar
Here is where I found the info:
Shops that don't recommend Carrera Tensioner Update?
Craig
G2Performance
Old 09-07-2007, 10:02 AM
They worked for me.
Back before they invented the tensioner upgrade I used them and they saved my engine on a 77 930. When the tensioner failed you could hear a noticable chain noise, however the hydra stops prevented total collapse of the tensioner. Really cheap insurance if running the original tensioners.
Old 09-08-2007, 07:41 PM
techweenie's Avatar
+1
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 09-08-2007, 08:00 PM
I made and installed the "internal" type also. I call them "Jerry Woods slugs". Turns out there is a bushing at Orchard Supply I think it is a 5/8" bushing made from brass. The OD of these fits perfect in the ID of the tensioner. Cut off a piece and sand down. I went with about a 1.5mm clearance. So far so good.
Old 09-11-2007, 08:14 AM
madpcar's Avatar
Great info guy's. Thanks for the help
Old 09-11-2007, 02:57 PM
