Valve suggestions for performance 3.2 SS
What valves (brand) are recommended for a high performance 3.2SS with 10.5-1 and twin plug heads?
1979 911SC 3.2 SS Custom Backdate Hot Rod 1972 911T, 2.7RS Spec Beck 904 Carrera GTS /3.6 2023. Macan Previously owned several 911 models since 1975. |
It's a 914 ...
How high you revving?
We are doing rods, springs etc., so we anticipate to rev over 7k when “needed”.
abit off center
Get a set of 8mm 993 valves and guides along with springs etc gives you a larger exhaust valve and 8mm stems
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
