-   -   Cylinder Head Gasket Orientation ? flat/round (http://forums.pelicanparts.com/911-engine-rebuilding-forum/367574-cylinder-head-gasket-orientation-flat-round.html)
GotaT 09-17-2007 06:06 PM
Ive pulled away my Heads from the cylinders tonight on my 2.4 because of a couple of Leaks coming between them.
I noticed that the a couple of Springs on the Cylinder Head Gasket (that sit on Top of the Cyliynders) had busted apart. The springs were completely apart and oil bypassing
What would cause this, ?
I also noticed on the New ones that these have a Flat side and a Round side
What is the Correct Orientation for Assembly?
Flat Side Down on the Cylinder ? ? ? (im guessing)
GotaT 09-18-2007 01:47 PM
Bump.. Anyone know the orientation and such.. ? ?
304065 09-18-2007 02:23 PM
It is not necessary to keep bumping your thread to the top of the page when it is only five or six threads down from the top.
sww914 09-18-2007 03:21 PM
I do it the way that you described and I haven't had any problems.
Keep in mind that I've built dozens of engines, not hundreds or thousands like some of the guys around here.
euro911sc 09-18-2007 03:22 PM
My guess, and it is a guess, would be flat side up against the head. I used to design similar metalic seals, but they were always symmetrical so it did not matter which way they were placed in the receiving channel. I say flat side up as that would be the leading edge and you may wish to have more sealing surface there, but I suspect it may not matter... Was there no spec sheet in the box?
I'll be interested to here the experts chime in.
Best regards,
Michael
