signature65's Avatar
2.4 MFI Heat Exchangers
Hey anyone know the difference with the heat exchangers made for carb vs MFI engines. I need some heat exchangers and there is a pair on ebay from a 70 911. Thanks
Old 10-10-2007, 07:57 PM
Loose nut bhind the wheel
Drivers side exchanger has an additional tube that is used to connect to the MFI pump thermostat. I do not know of any other differences. Can be used on carb car. Might want to plug the tube if you don't use it.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 10-11-2007, 07:21 AM
I have a pair of MFI heat exchangers from a 70E that are coming off shortly for headers. If you need any help, you can PM me.
Old 10-11-2007, 08:04 AM
