1972_911T's Avatar
Porting SC Heads
Is it worth the hassel to port small port SC heads or is it more cost effective to buy a set of early large port heads?
What would a typical machine shop charge for this?
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 10-14-2007, 03:38 AM
I've wondered the same. I don't think it's particularly difficult to open up small port heads to a larger port size, and you could certainly raise the ports if you ported out a small port manifold as well.
That said, I've just gone and bought a set of 3.2 heads for my rebuild, and will play with the small port SC heads when I have more time..
Earlysport
_____________________________________
69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930
IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD
Old 10-17-2007, 12:26 AM
Super Moderator
cstreit's Avatar
It ended up being close to the same cost when I've done it... With the added advantage of having the ports "cleaned up" around the valve guides and seats... I'd port 'em
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-17-2007, 07:18 AM
jluetjen's Avatar
The first -- not-so-obvious answer is: why? Are you going to be changing the cam spec or capacity of your SC motor? Or are you expecting to gain some HP just by porting the heads? Keep in mind that I believe Porsche quoted the same HP for both versions of the SC -- small and large ports. So unless you're going to change other stuff -- like cams and CR, it's not clear to me that it would be worth the trouble in and of itself.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-17-2007, 01:32 PM
1972_911T's Avatar
Yes the engine is been rebuilt as a 3.0 MFI Engine probably with S or Mod S cams.
Regards Steve
1972 911t RS Styled
Old 10-17-2007, 01:45 PM
