Eye of the Toiger
Max Moritz Pistons - What CAMS can I use
A friend of mine has got a set of Max Moritz Pistons for me, i want to take my 3.0 SC to a 3.2.
Now I was wanting to know what options do I have with regard to cam selection. I'm intending to use PMO 40mm carbs I was thinking of going 60 or 80 grind but not sure if these are too exteme for the MM pistons. I'd rather not machine the pistons as the compression is 9.3:1 I'd prefer it to stay there. If some one can guide me I greatly apprciate it. Matt
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
if your pistons look like mine i am using DC 62 cams (same as ge60 basically) i had no problem with clearence, these are 9.5:1 CR pistons. i'm not sure if they are Max Moritz type but they are 98mm mahles. i think actual Max Moritz pistons are a wedge type that have much less valve clearence, i may be wrong however. i've found that the pistons with the valve pockets that meet in the middle of the dome are 10.2:1 CR pistons.
Eye of the Toiger
They are the wedged shaped pistons for CIS
You are probably looking at a 964, web20/21 or DC20 ish grind cam then. I would contact Camgrinder on this forum or at www.drcamshafts.com to get a more specific idea. John grinds all my cams as well as many others on the forum.
The limiting factor will be your pistons, not your choice of induction. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I would rather be driving
If they are a CIS style piston then send them to Henry at Supertec and have pockets milled in the crown. THen you can use just about any cam you want. It will be worth the effort with carbs.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Not sure how much lower than 9.3 CR you would want. I think Henry posted about how much the CR was lowered with machining, but I can't remember the spec.
Cheers
