Addicted to Racing
edbaus's Avatar
Mix and match crankshafts
I have a 79 930 that I am currently rebuilding after a rod bearing failure.
I have my hands on an 86 911 crank that I was going to use. I see that the oil holes in the later crank are much larger than those in the 79. I had thought about using the case from the 86 but bagged the idea since the case would not match the car.
Is it ok to use the later crank in the earlier case.
Ed
Old 10-25-2007, 05:49 PM
304065's Avatar
Ed, the 3,2 crank has a stroke of 74,4mm vs. the 70,4mm of the 3,0 crank. As a result, they use different rods.
Most guys go the other way, short stroke crank from a 3,0 with larger pistons for a "Short Stroke 3,2."
More from our host here:
Quick FAQ 3.0/3.2 upgrades to 3.2/3.4
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-25-2007, 06:44 PM
I thought the 930 3.3 and the Carrera 3.2 crank were identical?
Old 10-25-2007, 06:52 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The 930 Turbo crank and the Carrera crank are identical accept for the flywheel locator pin in the Carrera.
The large oiling holes are a attempt to remedy the rod bearing failures associated with the 74.4 crank.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-25-2007, 07:20 PM
Addicted to Racing
edbaus's Avatar
So,
Can I use the later crank with the earlier case.
What is different about the locater pin.
Ed
Old 10-25-2007, 07:29 PM
