this case requies "oil bypass" or not?
this case requies "oil bypass" or not? 2.7MAG
Old 08-05-2008, 03:01 AM
abit off center
cgarr's Avatar
I don't see the return hole plugged, so I would say yes.
______________________
Craig
G2Performance
Old 08-05-2008, 05:04 AM
304065's Avatar
Dan, as you can see the return hole is still there (good eye Craig!). So this case will need the bypass mod.
That said, you should have this case inspected FIRST before performing any machine work, it's entirely possible that it is unusable due to the advanced state of corrosion visible. I would have it checked by a competent machine shop before starting work.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-05-2008, 06:30 AM
