After, a few years hold I am back at this project. I decided to split the case after finding missing or corroded material on piston #1 in the wrist pin area. This created some slop between the piston and pin. No bueno. Henry is sending me a replacement. He has suggested to cross drill the crank at the main bearings for better oiling and have the crank polished and balanced. Have the rods reconditioned and balanced and install ARP rod bolts with new rod bearings. Replace int. shaft bearings, cam chains. Inspect the main bearings, but possibly reuse them.
Here are some pictures of what the case has revealed. The main bearings aren't the most beautiful, and the nose bearing has some marring. Please Advise.. [IMG] [/IMG]
1981 911sc RoW Coupe (forever under 3.6L conversion) 2003 996TT Basalt black |
[IMG]
[/IMG]
Bump, looking for some advice from those more experienced in Porsche motor rebuilds...
Not experienced -- but you've gone this far and still have a ways to go.
Why not replace the bearings and have confidence in the end result. m
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
If $$$ is an issue, I'd trade the ARP rod bolts for new bearing every day! All the other items seem spot on. I'd add having the case checked for alignment. Ollie's did mine, (So long ago it was when they were in Santa Ana, Ca).
Not an expect. But I would always replace the mains - they are cheap. The nose bearing can be re-used but has a tendency to leak. Not sure if that is just at the outer O-ring that should be replaced no matter what or through the bearing itself. When I did mine I decided not to split the case and just did the rod bolts to ARP through the spigots.
Today 28,000 miles later the engine leaks at the nose bearing and I could kick myself that I didn't go all the way at the time..... And having the case checked is a good idea and insurance for a long living engine. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
