GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Persisten Oil Smoke STILL !! ARGGHH
I recently rebuilt the top end of my 2.4 and installed some upgraded cams.. Ive run the car for about an hour and dont see ANY oil leaks but am seeing Oil Smoke coming out from the Fan shroud through the Alt..
Anyone See this? Possibly know what it could be?
As a Rundown
Crankcase Breather is Not leaking
Cam towers arent leaking
Oil returns are Not leaking
No Covers are Leaking.
Only think I can possibly speculate is that there was some oil left on one of the manifolds that was not replaced and it is causing it.. Possibly.. ? ?
Or the Case halves are getting some oil bypass and burning?
Very Frustrating at this point.. Thinking of Selling
Old 11-05-2007, 05:56 PM
It wouldnt be to hard to pull the fan/house/alt and take a look inside. if it is oil on the exchangers there would be smoke coming out the bottom when the engine is on. If this is the case, just take it for a long drive on the highway to burn it off. Just make sure that is the problem before any long drives though.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 11-05-2007, 06:05 PM
gigem75's Avatar
if you do, let me know, over in east texas
Old 11-05-2007, 06:28 PM
911quest's Avatar
If you remove two heater tube plates one on each side of the Alt/fan you can get a good look at the top of the motor. Are you sure it is not dripping onto the muffler and rising up making it look like it's coming from the fan area.
Tony Proasi
1969S
1957 VW Pickup
Old 11-05-2007, 06:57 PM
GotaT's Avatar
Im sure there is nothing dripping on the Exhaust. Before my rebuild that Was the problem and now the parts all look VERY dry with nothing dripping.. I just dont understand it... : /
Old 11-06-2007, 06:38 AM
gigem75's Avatar
I'm guessing the smoke comes up after you shut the engine off?
I was just kidding about the selling,, take a deep breath, everything will be fine.
Are there any funny out of the ordinary smells or just that wonderful smell of the initial burnoff after the first crank. That smell is right up there with the new car smell imho.
Old 11-06-2007, 07:11 AM
GotaT's Avatar
Yes, Smoke comes up after the car is turned off. Im going to time the car tonight and run it longer to see if its just residue on the engine.. Boy do I Hope so!
I just dont SEE ANY drip of OIL Anywhere...
You shouldnt joke like that.. haaha
Old 11-06-2007, 07:34 AM
GotaT's Avatar
OK.. Update! Smoke has Subsided.. had to have been all sorts of chemicals left on top of the motor! WHAT A RELIEF! .. I would have thought it would have burned off sooner but apparently now...
The only thing I am seeing at this point is a little bit of "oil gloss" on the cam towers. No Droplets. All in All it is LOOKING GREAT! I just needa set my carbs a bit better.
Old 11-07-2007, 02:58 PM
