safe's Avatar
60-2 crank sensor wheel
Hi
I'm planing on getting an Emerald EFI for my 3.2 motor and I would like to use a crank trigger and coil pack setup.
The 3.2 has a 129+1 tooth flywheel sensor that is quite useless on anything but the stock motronic from what I heard.
Is there any aftermarket 60-2 trigger wheels that I can put om the flywheel instead of the "+1" ?
I have seen things that you put on the pulley, but that looks a little fragile if you ask me, I know what a broken fan belt can do...
Magnus
Old 11-03-2007, 03:29 AM
1972_911T's Avatar
Check out clewett's website they sell electromotive stuff that im sure uses 60-2 also check our host as they sell electromotive as well.
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 11-03-2007, 04:29 AM
David's Avatar
If you go with Motec, it can read just about any number of teeth.
Old 11-03-2007, 07:13 AM
Flywheel
Have your flywheel machined to make it what you need, we can do it if you like
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-03-2007, 07:47 AM
Navin Johnson
TimT's Avatar
You can use a trigger wheel on the crank pulley with no worries. We have many cars with 60-2 trgger wheels mounted on a crank pulley
'69 911 GT-5
'75 914 GT-3
and others
Old 11-03-2007, 09:48 AM
safe's Avatar
That would be the cool thing to do, if you ask me. Thank you for offering, but the shipping would kill me!
The Electromotive pulley looks sturdy.
What do the 3.6 conversion guys do? They can't use the 3.6 flywheel and clutch with a 915 box, can they?.
Magnus
Old 11-05-2007, 02:09 AM
Flywheel
If your system can use the Porsche sensor with the modified tooth pattern that would be hard to beat overall, there are alot of reliability issues with the electromotive sensors, the conversion guys are either using the G 50 or a Patrick Motorsports flywheel, we make a flywheel that will work but it is a race only 5.5 "multi disc unit.
Mike Bruns
Old 11-05-2007, 04:47 AM
safe's Avatar
Mike Bruns
Are the issues with the electromotive sensor itself or the sensor-by-the-pulley setup?
Since it's a street/DE car I like reliability
Magnus
Old 11-05-2007, 12:48 PM
sensors
We ran the Electromotive systems for years and the biggest failures were the sensors, all the units we ran and others that we serviced were the 60 minus 2 pulley style in 3/8" and 1/2'' sensors, the boxes were the HPV1 they worked good but the later HPX boxes were JUNK, If it were mine I would go with the stock sensor and figure out the flywheel, some of the Motec systems that we used on the 3.8 RSR engines that used the stock flywheel's and sensors we had to increase the air gap because the signal was very strong at the stock gap, then they were happy.
Good Luck with your project, Mike Bruns
Old 11-05-2007, 01:09 PM
Insane Dutchman
Is the sensor just looking for a small gap in signal? I am fitting a 6 speed G50 to my '89. was still puzzling over the EFI stuff and prepared to go with the pulley sensor if needed.
I am fitting an early Turbo flywheel, is it possible to just machine grooves in the flywheel flange at the appropriate spacing? Will the sensors (Motec or who's ever) respond to the gap?
Any insight is welcome...
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 11-05-2007, 01:27 PM
triggers
We do a few for the 944 turbo guys that want a 36 minus 1 setup and usually begin with the original tooth and make that one the missing and drill and tap one every 10 deg. screw in an allen set screw or the like and lock tite it in then machine them true on the lathe, that setup works fine when you dont have much room or any trigger teeth to begin with. Each managment system has it preference on tooth count and the type of sync signal to find itself each revolution.
Mike Bruns
Old 11-05-2007, 02:58 PM
Navin Johnson
TimT's Avatar
The sensors had a tendency to fail, especially the older 3/8" sensors, the newer 1/2" sensors seem to be of better quality and are more reliable.
I heard from someone that the original electromotive crank sensors were really an off the shelf proximity sensor that was used for some manufacturing process, not an automotive specific sensor.
'69 911 GT-5
'75 914 GT-3
and others
Old 11-05-2007, 08:14 PM
safe's Avatar
Thanks everyone, especially Mike. I now know what I can and must do.
I might post a thread later on how the project (EFI with ITBs from a Suzuki on a 3.2) is going when I'm a bit further in it.
Magnus
Old 11-06-2007, 12:30 AM
safe's Avatar
An update.
Like the cheap bastard I am, money made the decision
I bought a pulley mounted 36-1 trigger wheel and modified the original sensor bracket.
Anyone know why Porsche used a steel sleeve on one of the original 3.2 sensors?
Magnus
Old 01-28-2008, 02:23 PM
Which TB are you using? I am going to try out a set from a GSRX 600 which are 38mm, trying on a 2.4 first, and then a 2.7 if that works out.
Robert
Currently Porsche less (but the wife has 2)
Old 01-28-2008, 05:10 PM
safe's Avatar
I'm using TBs from 3 Suzuki TS1000 (a v-twin).
They are 48mm, which can probably be a tad to big on an otherwise stock 3.2, but they were cheap and available... The 3.2 might not be stock forever, so I'm building for the future. In either case it will be better than my tired 2.7.
Magnus
Old 01-28-2008, 11:51 PM
