dtw dtw is offline
GAFB
So who has the record for the most broken head studs?
My previous record was four. I pulled the covers on a motor tonight and found six broken. Half of them came tumbling out and went plop into my oil drain pan. I'm sure someone has had worse - let's hear those horror stories!
Several BMWs
Old 12-12-2007, 09:51 PM
Super Moderator
cstreit's Avatar
I was going to "brag" about the four that I found, but you sir are the winner!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-13-2007, 09:24 AM
dtw dtw is offline
GAFB
Chris, man, it was funny. I popped the last nut on the cover, and the cover slides off, and suddenly I am hearing "PLOP PLOP PLINK PLOP" as all the broken hardware falls out and splashes me with oil as it plummets two feet into my drain pan. Fished everything out and put magnets on them....of course I already knew the answer though, didn't I? All the intake side studs are intact...hmmmmmmm wonder what they're made of.
Over the last month or two I've been seeing some good horror/freakshows, and have begun assembling a bucket of really nasty parts. Does anyone remember Doug Zielke's mechanical mayhem file? Well, I'm resurrecting it. So far I've got:
-Six asploded Dilivar studs
-One completely beat-to-***** 2nd gear dogring (what happens when you continue driving a 915 when the synchros have given up)
-Five nasty, pitted, worn-out synchros (show the dangers of neglecting your tranny fluid)
-Early idler supports with friction-welded/galled bores (why bearing-less/narrow idler supports are potential time bombs)
-Ultra-worn cam/layshaft sprockets that lead to:
-Layshaft bearings showing WAY too much copper for an 85k engine
People are welcome to send me their over-worn or catastrophically failed parts. I have been brewing an idea for a thread(s) that show the dangers of half-assed engine/trans builds or ignoring the warning signs of impending failures.
Several BMWs
Old 12-13-2007, 10:15 AM
sww914's Avatar
I pulled apart the engine of an absolutely pristine SC with 20something thousand miles on it with 7 broken head studs. This was in '02.
Some kind soul had RTV'd the broken pieces of 5 of them back into the holes, then 2 more broke.
Old 12-13-2007, 09:41 PM
