Im getting about 15.5 IN TOWN driving with of course spurts of power! on my 2.4 w/ Webers
Still have yet to check it on the HWY.. but I know I need some throttle shaft repair.. = not tuned the best right now. |
I did a little checking on my Webers this week but the batteries were dead so I couldn't fire it up. I removed the idle mixture screws and the air correction screws to spray some carb cleaner in the holes and clean things up a bit. There wasn't much build up at all but I did notice the air correction screws are all nearly bottomed out. Is that a normal setting? Last time I checked with my synchrometer the throats are all balanced very well.
http://forums.pelicanparts.com/uploa...1197056796.jpg http://forums.pelicanparts.com/uploa...1197056803.jpg The idle mixture screws are also nearly all the way out, maybe one turn in on each cylinder. |
As for the idle mixture screws, they have more travel and adjustment range than one turn out from seated, which, btw, seems about right. Sherwood |
Thank you for the help Sherwood. My idle mixture screws are actually one turn in, the spring seats on the carb body and then they are about one/half to one full turn in from that. I assume that is nearly full rich.
I am planning on making sure the idle and main jets are clean when I get back home this week. The intake gaskets need to be checked as well so I'll be picking up either ether or carb cleaner for that. Hopefully I can get a video up soon so you guys can see how she runs. |
Sounds like you have a fairly rich idle mixture if you're using the spring as a reference. The correct reference point is to start with all the mixture screws lightly seated, then back them off approx. 1 - 1 1/2 turns. I would also recommend a Synchrometer and a CO meter to monitor the settings while adjusting. Idle mixture settings are fairly sensitive to small changes, and since the idle circuit is still active into the cruising range, a rich idle setting will affect overall fuel mileage more than one would expect. Sherwood |
Well since my speedo reads 85 @ 3800 upm in 5th and I know it's not 85 because the wheels are 14's and I'm assuming it's calibrated for 15's I'd probably break 20 going 3300? @70. With 15's, 19.8 @ 85 and 3800 would be pretty good? I'm not taking into account the exta aero drag so we could call it maybe 19, 18.5?
This is a great thread for webers http://forums.pelicanparts.com/911-engine-rebuilding-forum/239742-71-t-still-backfires.html |
I followed the suggestions on the thread suggested by gigem75 and was able to tune my carbs.
Then I filled it up and did some driving. The improvement in gas mileage was actually really nice! I think I was getting around 14 or 15 miles per gallon before tuning the carbs. My last gas tank which was admittedly 70% highway 30% city averaged 23mpg! I am going to run this next tank with more of a 50/50 split so we'll see how that one goes. |
It was 31 degrees this morning and with a couple of squirts with the pedal she fired right up. Took a little finesse with the throttle to keep it running, it did die once or twice but all things considered espeically no cold start aids other than pumping the gas pedal it went fine. My original 18 mpg was on a very fresh complete engine rebuild and I've since refined the carb adjustments I would expect it to be better now. Having 14 inch wheels doesn't help though.
My car is the same way on startup, it's a little fussy at first and then calms down.
I have 15x7s and 8s with RS flares on the rear and a '74 915. My order for just went through Pelican to repack my CVs with new boots, put Swepco 201 in the trans, and I might pick up some Brad Penn for the oil change. We'll see if any of that effects the mileage. |
my dreamometer says I'm doing 85 at 3800rpm so I'm sure it came with 15's
I wanted to refresh this post a bit. I just got my Webers back and have tuned them. I am only getting about 13 in town, whereas before I was getting around 16. They were bored from 40 to 41's.. I know this will have some effect but I think I should get at least 16 still IN TOWN..
I will be taking a trip from Laf to Houston this weekend and am wondering If I should make any changes to my MIX screws before I hit the road.. Sounds like some of you have been able to make changes AND havent complained about any extra POPPING OR SPITTING than before.. What did you do.. I think we would agree to get bettter economy you would need to lean them out a bit |
I leaned out the idle circuit on mine according to instructions posted by Steve at Rennsport. I seem to be getting much better gas mileage than before and the exhaust is less eye watering. My understanding is that at cruising load on the highway you are still running on the idle circuit so that would have a big effect on the fuel economy.
I have Weber 40s on what I think is a 2.2. |
Where are the instructions by Rennsport, or do you have them, id be interested in seeing if they are the same or similar to what I have.
Thanks |
I can't find Steve's post but here is a good one.
Great write up by John
double check your ignition timing, I was chasing some spitting and popping with the carbs and it ended up being the timing. Don't ask how it got that far out overnight because unless I changed it while sleepwalking I have no clue.
Really!? ... What did you set your timing to? I think mine is about 15 ATDC per instruction given to me.
What engine are you running? |
I think that sounds like a severely retarded setting, you might try running it more advanced. I think the spec is 5BTDC but you have a 2.4 in there so it may be a little different.
edit: It looks like a 2.2 should be 0-2 degrees ATDC according to the fan strap sticker on a 2.2 911E. A 2.4 T E or S should be 5 degrees ATDC Is your exhaust really hot with a 15ATDC setting? |
2.2 and if I remember correctly I think it's 5 before. I've got the marks lined with white paint to see it better under the light. Everything was great and then one morining she was spitting and coughing, really weird, even took one apart completly and checked everything. Then checked the timiing and it was way off, at least 10 degrees, weird. Set it back to 5 before or whatever the mark next to tdc is and life is good.
If it is 5 after that is probably to meet emissions and 5 before might work better? |
GotaT,
You asked if leaning out the idle fuel mixture screws would help your mileage on your trip from Laf to Houston. Remember with Webers the engine runs on the secondary venturi at rpm's above 2500/3000 rpm's. Any adjustment of the idle mixture will not affect your mileage at hiway speeds. For better mileage at hiway speeds you'll want a smaller venturi and corresponding smaller main jets. You want better mileage around town? Smaller venturi and smaller idle jets; then retune. The Webers get fuel from the idle passageways to the idle and transition jets at rpm's below 2500/3000 rpm's. You end up trading better mileage for less performance. |
| All times are GMT -8. The time now is 03:08 AM. |
