-   -   Twin Plug?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/378939-twin-plug.html)
1972_911T 11-24-2007 04:36 AM
Twin Plug??
Im in the process of rebuilding my 3.0 engine, im ditching the CIS in favour of EFI and will be running 9.8:1 CR pistons probably with 964 cams. Should I twin plug the motor? If so is this just for safety or will it give me any extra HP from running a more suitable advance curve ?? Car will be run on 95RON fuel.
cstreit 11-24-2007 07:47 AM
I think that's going to net out to about 89 octane US numbers? That's pretty close to the limit there. You'd be safe with conservative advance numbers and a richer mixture on 93 octane (US) but not so sure on your configuration. I'm sure Steve "octane" Weiner will chime in here...
BURN-BROS 11-24-2007 08:10 AM
9.3 is all I would go on single plug. 9.8 will not net you any power over 9.3 if you cannot run a healthy advance.
Henry Schmidt 11-24-2007 08:55 AM
Higher cylinder pressures at all rpm ranges (torque), smoother running due to more complete fuel burn and a more aggressive advanced curves without detonation using lower quality fuels are the benefits of twin plugging the hemi head configuration used by the Porsche 911.
That was a mouthful!
hobieboy 11-24-2007 04:46 PM
Hi Henry,
I thought because twin plug produces more complete burn one should run less advance?
Henry Schmidt 11-24-2007 06:06 PM
Originally Posted by hobieboy (Post 3605505)
Hi Henry,
With twin plug the net result is a more aggressive curve with less total advance.
Aggressive does not always equal more. Aggressive as I meant it = quickly accelerating, tending to move/change rapidly.
Aaron / Burn-Bros is the resident distributor expert, perhaps he's chime in.
hobieboy 11-25-2007 04:35 AM
Thanks Henry... got it now :)
1972_911T 11-25-2007 01:13 PM
Ok im sold on the twin plug just been and exchanged my heads for a set of ready twin plugged ones.
Now moving on to spark control one of the things that has worried me about running twin plug and hence a more risky configuration is what happens if you get a failure. Im planning on running a electronic ignition setup using wasted spark. From reading on the subject I know its recommended that one dual coil fires two opasite cylinders the theory being that the cylinder under load has the densist air and hence gets most of the spark energy, but wouldnt it be safer to run both plugs on one cylinder from the same coil then if there is a failure of the coil you will get no ignition rather than just one plug igniting?
or is there not enough energy to properly fire both the plugs?
Jeff Alton 11-25-2007 03:09 PM
You need to fire the top and bottom plugs from different coils, there is not enough energy to do it with one.
Search my user name and coils on the tech board and you will find a great thread about.
Cheers
safe 11-25-2007 03:46 PM
Originally Posted by 1972_911T (Post 3604671)
I'm ditching the CIS in favour of EFI Steve
What EFI-system will you be using?
1972_911T 11-25-2007 04:00 PM
Im going to give MS a try, ive just bought a TBitz partial setup and considering ITB's, I like the look of the new PMO's. I was all geared up to build a 3.0 MFI engine but for various reasons gave up on that, this will be a nice alternative and if I do end up with ITB's it wont compromise the look of the MFI that was original to my car too much.
Jeff Alton 11-25-2007 08:46 PM
If you are thinking ITB's, I have the Jenveys and they are nice, but I will be back to back testing them with the new ones from Mark Hargett, and his look beautiful! I should have some results just after X-mas.......
Cheers
safe 11-26-2007 02:03 AM
I'm building an ITB setup on a 3.2 that I have. I thinking of using the Emerald system, have you considered that?
At £580+taxes its not very expensive and it will also control the ignition.
1972_911T 11-26-2007 02:25 AM
Just had a quick look at it and it only has 3 coil drivers so will only be able to fire 6 plugs in a wasted spark config so no good for a twin plug engine. Unless each coil driver could fire 2 simultaneous coils??
safe 11-26-2007 04:25 AM
That can't be a problem, can it?
I would drop them a mail about it. I'm not buying anything just yet, but I would prefer a "proper" EFI system with support to a DIY Megasquirt.
I have talked to several shops and they all say that the 12x12 injection map of the Megasquirt is to small, at least for a high performance engine with high lift and overlap.
A system that some shop that you trust can map is also good. I don't think you can map it properly without a dyno.
1972_911T 11-26-2007 04:48 AM
Another option is the DTA systems there a little more expensive depending which model you go for, there based in the UK like the emerald. If the MS doesnt prove to be waht im looking for I think thats what I will go with. Probably the S80.
http://www.dtafast.co.uk/
Jeff Alton 11-26-2007 06:09 PM
I am pretty happy with my microtech and its iginition expander that allow me to fire 6 two pole coils. Software is pretty easy to use as well.
Cheers
TimT 11-26-2007 10:20 PM
With three ignition drivers you can easily control the ignition for a twin plugged six
you need two three channel ignitors, the output signal from the ECU's ignition drivers is split and feeds one each of the ignitors, each ignitors output goes to a twin tower coil.
This schematic from show how to wire it , you just use another whole set up like this fore the other set of plugs.
we use Bosch 0227 100 203 ignitors
http://forums.pelicanparts.com/uploa...1196144354.jpg
CruiseControl 11-26-2007 10:28 PM
Steve, for wasted spark you only need three output drivers. Each output should be capable of triggering a pair of ignition modules. refer to the below wiring diagram which uses two Bosch 0 227 100 209 ignition modules which fires two 6 pack coils. The terminals A3, A4, A5 are the switch outputs of the ECU.
http://forums.pelicanparts.com/uploa...1196144822.jpg
Paul
hobieboy 11-27-2007 06:28 AM
Steve, as others have pointed out, with wasted spark you only need 3 outputs from the MS. This is the config that I'm running with MS right now. I also built the ignition drivers based on MS "recommendations" - way cheaper and allow me to "integrate" it directly to MS.
You do want to fire each cylinder from 2 different coils - though I'm still not 100% convinced its a must, but this is the "normal" way to set up wasted spark.
safe 11-27-2007 03:09 PM
Nice, those are affordable and plentiful from the junkyard.
What coils do you use?
