Twin Plug??
Im in the process of rebuilding my 3.0 engine, im ditching the CIS in favour of EFI and will be running 9.8:1 CR pistons probably with 964 cams. Should I twin plug the motor? If so is this just for safety or will it give me any extra HP from running a more suitable advance curve ?? Car will be run on 95RON fuel.
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 |
Super Moderator
I think that's going to net out to about 89 octane US numbers? That's pretty close to the limit there. You'd be safe with conservative advance numbers and a richer mixture on 93 octane (US) but not so sure on your configuration. I'm sure Steve "octane" Weiner will chime in here...
9.3 is all I would go on single plug. 9.8 will not net you any power over 9.3 if you cannot run a healthy advance.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Try not, Do or Do not
Higher cylinder pressures at all rpm ranges (torque), smoother running due to more complete fuel burn and a more aggressive advanced curves without detonation using lower quality fuels are the benefits of twin plugging the hemi head configuration used by the Porsche 911.
That was a mouthful!
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-24-2007 at 09:00 AM.. |
I thought because twin plug produces more complete burn one should run less advance?
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Aggressive does not always equal more. Aggressive as I meant it = quickly accelerating, tending to move/change rapidly. Aaron / Burn-Bros is the resident distributor expert, perhaps he's chime in.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-24-2007 at 06:31 PM.. |
Thanks Henry... got it now
Ok im sold on the twin plug just been and exchanged my heads for a set of ready twin plugged ones.
Now moving on to spark control one of the things that has worried me about running twin plug and hence a more risky configuration is what happens if you get a failure. Im planning on running a electronic ignition setup using wasted spark. From reading on the subject I know its recommended that one dual coil fires two opasite cylinders the theory being that the cylinder under load has the densist air and hence gets most of the spark energy, but wouldnt it be safer to run both plugs on one cylinder from the same coil then if there is a failure of the coil you will get no ignition rather than just one plug igniting? or is there not enough energy to properly fire both the plugs? Steve
You need to fire the top and bottom plugs from different coils, there is not enough energy to do it with one.
Search my user name and coils on the tech board and you will find a great thread about. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
What EFI-system will you be using?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Im going to give MS a try, ive just bought a TBitz partial setup and considering ITB's, I like the look of the new PMO's. I was all geared up to build a 3.0 MFI engine but for various reasons gave up on that, this will be a nice alternative and if I do end up with ITB's it wont compromise the look of the MFI that was original to my car too much.
If you are thinking ITB's, I have the Jenveys and they are nice, but I will be back to back testing them with the new ones from Mark Hargett, and his look beautiful! I should have some results just after X-mas.......
Cheers
At £580+taxes its not very expensive and it will also control the ignition.
I would drop them a mail about it. I'm not buying anything just yet, but I would prefer a "proper" EFI system with support to a DIY Megasquirt. I have talked to several shops and they all say that the 12x12 injection map of the Megasquirt is to small, at least for a high performance engine with high lift and overlap. A system that some shop that you trust can map is also good. I don't think you can map it properly without a dyno.
Another option is the DTA systems there a little more expensive depending which model you go for, there based in the UK like the emerald. If the MS doesnt prove to be waht im looking for I think thats what I will go with. Probably the S80.
http://www.dtafast.co.uk/ Steve
I am pretty happy with my microtech and its iginition expander that allow me to fire 6 two pole coils. Software is pretty easy to use as well.
Cheers
Navin Johnson
With three ignition drivers you can easily control the ignition for a twin plugged six you need two three channel ignitors, the output signal from the ECU's ignition drivers is split and feeds one each of the ignitors, each ignitors output goes to a twin tower coil. This schematic from show how to wire it , you just use another whole set up like this fore the other set of plugs. we use Bosch 0227 100 203 ignitors
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Steve, for wasted spark you only need three output drivers. Each output should be capable of triggering a pair of ignition modules. refer to the below wiring diagram which uses two Bosch 0 227 100 209 ignition modules which fires two 6 pack coils. The terminals A3, A4, A5 are the switch outputs of the ECU.
![]() Paul |
You do want to fire each cylinder from 2 different coils - though I'm still not 100% convinced its a must, but this is the "normal" way to set up wasted spark.
