2.4 vs. 2.7 crank shaft
Can anyone help me understand what the differences are between a 2.4E and 2.7E crank shaft?
I have a 2.0l aluminum case that I am preparing for displacement increase.
I have 2.4 P&C for the engine and I have 2.4S heads and cams.
Is there a difference in stroke between these two crank shafts?
Thanks all,
Old 11-30-2007, 04:22 AM
dtw dtw is offline
GAFB
All production 6-bolt 70.4mm cranks are the same.
Several BMWs
Old 11-30-2007, 06:15 AM
304065's Avatar
They are both 70.4 stroke. You will also need rods for a 70.4mm crank, they are shorter and have a wider bearing saddle. The rod/stroke ratio is not as favorable as the 66mm crank.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-30-2007, 06:35 AM
Your crankcase may need to be clearanced so the bottom of the pistons doesn't hit the case. A good Porsche machine shop can confirm this and do the work. My machinist is Ted Robinson at German Precision (408) 747-0728.
-Andy
Old 11-30-2007, 08:00 PM
