cowfly911's Avatar
Thoughts on this engine stand yoke
I will be starting on my 911 engine rebuild soon and was looking for an engine yoke. Saw this one on eBay for $89...
Any thoughts/experience with this item?
http://cgi.ebay.com/ebaymotors/PORSCHE-VW-4-ARM-ENGINE-STAND-YOKE-TOOL-Made-in-USA_W0QQcmdZViewItemQQcategoryZ43998QQihZ008QQitem Z180196360648QQrdZ1QQsspagenameZWDVW
1983 911 SC "RoseBud"
1980 911 SC "Silver"
1966 912 "Red"
Old 12-18-2007, 09:57 AM
Racer
preston_brown's Avatar
I have a 2 arm stand for my 356 motor from VW Alley, and a couple of motor dollys. All their stuff is made in the USA in-house, and is solid. While I haven't used this particular yoke myself, I would not be afraid to do so from my previous experience with them.
Preston Brown
Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn)
1965 356 C Coupe | 2010 F250 (support vehicle)
Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera
Old 12-18-2007, 10:32 AM
sww914's Avatar
I also bought the 2 arm VW stand from him. It says not to put anything bigger that a VW engine on it, but I haven't put anything other than a Porsche 6cyl on it. It's scary and I support the pulley end of the engine with a 4X4 until it's stripped down.
Good quality stand, great price, but I wish that I'd bought the one that you're looking at.
The seller's a good guy.
Old 12-18-2007, 11:43 AM
wmunchovie's Avatar
If you get it please post the results as I was toying with buying this particular model from ebay....
thanks,
munchovie.
Is 13 lucky or unlucky ?
Old 12-18-2007, 05:18 PM
I bought one, it is well built and I wouldn't hesitate to use it for almost any 911 motor. Maybe not a full on turbo with all components attached, but it is certainly sturdy enough for any NA motor. You do need to fit it to your stand as they weld some dimples on it that need to be ground down until it will slip in.
Robert
Currently Porsche less (but the wife has 2)
Old 12-18-2007, 06:00 PM
notmytarga's Avatar
I just bought the $69 three spoke yoke. On it's way - reading the descriptions these things are beefy and the four spoke should at least match the five spoke model that is recommended. I figured for my 2.7 the three spoke would be adequate. Turns out these are made in the hills above Chico CA - very close to me. I'lll update if my opinion changes.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 12-23-2007, 04:23 PM
azporsche911.com
Hoffmanmotors's Avatar
Yes please do, I got a 1000lb engine stand from harbor freight for xmas and now i need the yolk for my engine.
Jeff Hoffman (Son)
Tom Hoffman (Father)
79 911sc ROW guards red coupe
father son project.
Old 12-26-2007, 02:44 PM
notmytarga's Avatar
My Yoke arrived today - I got the 3 vs the four spoke model. It came with a heavy guage adapter sleeve to adapt it to the engine stand which has six spot welds on its exterior. I ground those down a bit too much to give the adapter sleeve a tight fit in the engine stand pipe. I next drilled four 9/24" holes at 90 degrees through the smaller pipe on the yoke itself.
The yolk came with one M12? bolt, a nut and a standoff sleeve. Not two sets.
The instructions recommend attaching to the left engine half. This seems to be because there is more room over there without the engine cooler. In fact the mounting ring would not sit flush it it were mounted against the cooler. The fit on the left side was perfect. Pictures of the yoke in Waynes book show a two level mounting plate that keeps it away from the oil cooler. Using the oil cooler side is best to facilitate dealing with the oil pump on the still attached half. More opinions once I put it up on the stand.
Old 12-26-2007, 05:09 PM
