CBRacerX's Avatar
Where to buy Speedi-Sleeve?
Our host doesn't carry these, anyone have a source (and possibly the model used for the 964 rear main seal surface...)?
http://www.chicago-rawhide.com.au/Products/speedisleeve.htm
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 12-26-2007, 11:51 AM
3.2 CAB's Avatar
I have used these types of repair sleeves before. It was not for a Porsche. The results great, it quickly took care of the leaking front oil seal and harmonic damper on a few vehicles over the years. After installing the sleeves, ZERO leaks. Still no leaks, and it has been 6+yrs no on the last one I did. I believe that I purchased them either from NAPA, or CARQUEST. Good luck!!
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-26-2007, 12:31 PM
911quest's Avatar
Stoddard list's them for some models I hope that helps
Tony Proasi
1969S
1957 VW Pickup
Old 12-26-2007, 12:35 PM
rsscotty's Avatar
Link to sizing catalog.............
http://www.acorn-ind.co.uk/pdf/prspeedi.pdf
Old 12-26-2007, 03:55 PM
CBRacerX's Avatar
thanks! I send Stoddards a message - they don't seem to stock the 964 flywheel end sizing.
Chris
Old 12-26-2007, 05:01 PM
3.2 CAB's Avatar
Hi everyone, I have been using these types of shaft end repair kits for many years. I have never had a problem with any of them, regardless of the manufacturer. I really liked the link that was posted, gave a better insight on the item. CBRacerX, if you send me the specs, I can check here locally for one. I have always been able to get whatever I needed, even if they had to order it, I got it the following day. Let me know and I will check for you. Good luck, Tony.
Newest additions-
others...
Old 12-29-2007, 06:42 AM
CBRacerX's Avatar
As it turns out, Stoddards does carry the part for the rear main seal. I ordered one.
Chris,
The speedi sleeve p/n SIC-102-993-51 will fit all 9 bolt crankshafts 1978 to 1998. They are $41.50 and are in stock.
Regards,
Mike Garriga
911 Parts Specialist
Stoddard Parts
mgarriga@*************
1-800-342-1414 ext 3071
Chris
Old 12-29-2007, 08:44 AM
3.2 CAB's Avatar
Great to know.
Newest additions-
others...
Old 12-29-2007, 10:55 AM
