1972_911T's Avatar
Rod Bolt Loktite
Why do the original rod bolts use loktite while aftermarket ones dont? Is there something inherent with the original stretch bolts that makes them more prone/likely to come lose than ARP and the like or is it just belt and braces approch by porsche?
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 01-02-2008, 02:16 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The ARP rod bolts are a higher quality of material. This allows for higher torque values and less likelihood of loosening.
BTW: I don't think the factory suggests Loctite on rod bolts.
We use Loctite on factory rod bolts in racing engines but not street engines when we are forced to use factory bolts.
We also use a 12 point, serrated flange rod nuts on all 10 mm rod bolts in racing or street application.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-02-2008, 06:20 AM
abit off center
cgarr's Avatar
You could use Castellated nuts and drill the bolts if you like overkill. I like Loctite, I like the no risk approach.
______________________
Craig
G2Performance
Old 01-02-2008, 06:41 AM
1972_911T's Avatar
That explains the lack of any trace of loctite on the old bolts I removed then.
1972 911t RS Styled
Old 01-02-2008, 07:47 AM
If you used anti-seize on the rod bolt threads, Loctite wouldn't serve any purpose. Threads must be clean and pristine for Loctite to have any effect. And if you did, the torque settings wouldn't be accurate (although I'm not sure how well Loctite acts as a thread lube).
Sherwood
Old 01-02-2008, 12:09 PM
