Can I build a 2.5SS?
Ok, I've had a look through my storage boxes and here's what I've got:
2.4E complete engine, (now in bits), with MFI. Everything is in good order and the cases are 4R/5R halves.
90mm Mahle cylinders.
90mm Mahle MFI pistons.
66mm non-counterweight crankshaft and rods, from a 'T', if I recall correctly.
I'm aiming to build an engine for my project car and am leaning towards a short-stroke, so I'm thinking of putting the bits together and building a 2.5SS MFI motor. Obviously I'd have the cases shuffle-pinned, etc.
Couple of questions for you:
1 Will the parts go together to build such a motor and will it survive or be a very expensive bang?
2 Would the MFI pump need major alteration?
3 Are the 'E' cams the best option for an engine that will see track work but that still needs to be useable on the road?
All comments gratefully received!
Old 12-31-2007, 08:08 AM
andrew15's Avatar
The T crank will fit and give you a 2.5 short stroke engine, but the 90mm MFI pistons are probably what I call RS Pistons and were only a 8.5:1 compression on the 70.4mm crank - with the 66mm compression is down to about 7.5:1
I know people have built an engine with this combo, but I'm not sure how the low compression worked out.
Specifically,in answer to your questions:
1) As long as you aren't spinning the engine to 7k rpm all day long, the T crank should work fine
2) The pump can probably be recalibrates - which one do you have?
3) E cams would probably be the best with the low compression ratio, but see if you can et a ride with an S-cammed car. I have S cams in my 2.6L SS and it's fine on the street.
I'm sure others will chime in
Regards,
AM
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 12-31-2007, 08:48 AM
