degreeoff1's Avatar
niki VS alusil ID?
How do I tell which is which?
1972 914-6 in the works.....
2003 Ford E-250 "work horse"
2004 Yamaha V-star Classic 1100 "early mid life crisis"
2005 Scion XB "Gas sipping"
1978 Siedelmann S25 "Ataraxia"
Old 01-05-2008, 06:44 AM
MarKoBrow's Avatar
I think you will find all your answers here, what year is your motor?
[URL="http://forums.pelicanparts.com/showthread.php?t=73286"]
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 01-05-2008, 06:48 AM
degreeoff1's Avatar
Beats the hell out of me....I am dealing with 2 different sets one is a 74?? and the other a unknown.......I have these from various parts motors....I was rather hoping that the ID #'s on the cylinder bases would tell the story...is it in waynes book? (which I have)
Old 01-05-2008, 06:58 AM
abit off center
cgarr's Avatar
I check mine with a magnet, the niki's will be slightly magnetic..
______________________
Craig
G2Performance
Old 01-05-2008, 07:04 AM
Stranger on the Internet
patkeefe's Avatar
One type has 10 fins, and the other has 11 fins. I forgot which is which...wait let me look in the basement...OK, nikasil has 11 fins. Also, the Kolbenschmitt cylinders will have some KS markings on them.
PLEASE wait til someone else can veify this. I don't know if the 10/11 rule applies to all years, I know it does for my 3.0 engine. The cylinders I just looked at in the basement are 2.7 Mahle.
Pat
Patrick E. Keefe
78 SC
Old 01-05-2008, 09:53 AM
notmytarga's Avatar
If you look inside them:
the nikasil's bore looks like brushed steel and
the alusil's bore looks like a creamy grey primer coating.
Telling from the exterior would be simpler but is less clear.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 01-05-2008, 03:41 PM
abit off center
cgarr's Avatar
I have a set of 74 nikasil 2.7 cylinders right here and they do have 11 fins too..
Craig
G2Performance
Old 01-05-2008, 03:48 PM
degreeoff1's Avatar
Yep I do believe that both sets I have are Niki's as they #1 both have a 11 count fins and #2 they are both slightly magnetic....AND zero visable wear so...I guess I am good to go and will have at least 1 set of 2.7 CIS P & C's for sale very soon as the other set are matched to Ross pistons...:-)
Thanks guy's
Josh
Old 01-05-2008, 07:13 PM
abit off center
cgarr's Avatar
Excellent!! Should I go post a WTB add now
Craig
G2Performance
Old 01-05-2008, 07:57 PM
The magnet is the definitive test.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-05-2008, 08:01 PM
dtw dtw is offline
GAFB
Thanks guy's
Josh
A visual test doesn't automatically green-light the barrels. They could be way out of spec for ovality and still look great. The ring lands on the pistons could be shot, too.
I just went through 13 sets of used 90mm CIS pistons and cylinders looking for a set that was 'truly' good enough to re-use...struck out.
Not trying to say yours are bad - just that you should measure all the specs before re-using them or selling them as 'good'.
Several BMWs
Old 01-06-2008, 05:08 PM
degreeoff1's Avatar
My pistons are GREAT 920mile Ross.....Now I need to know if my deck height of .89 mm is OK?
Old 01-06-2008, 05:10 PM
