Nitrometano's Avatar
Wrist Pin Bushing
Hello guys,
I have a question about the wrist pin bushing (rod small end bushing) that Pelican's sells. The part number is 901-103-131-01-M41 and his brand is Glyco.
I know that the aftermarket wrist pin bushings like the solid ones that the machine shops do, nees to be reamed or bored to the factory specs size. This ones, the Glyco that I mentioned, need to be reamed or bore to factory specs or is just an press in and all is done?
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 01-28-2008, 11:45 AM
