Cam tower plug sealant
I had to remove the 49mm end caps on the cam tower for some work. What is the proper sealant to use when replacing the plug? Is Loctite 574 OK?
sealant
A light coat of 574 loc tite will work fine, even blue 242 will work in a pinch.
Mike Bruns JBRacing.com |
Thank You Mike.
| All times are GMT -8. The time now is 06:22 AM. |
