356RS's Avatar
Cam tower plug sealant
I had to remove the 49mm end caps on the cam tower for some work. What is the proper sealant to use when replacing the plug? Is Loctite 574 OK?
Mark Jung
Bend, OR
MFI Werks.com
Old 01-28-2008, 03:32 PM
sealant
A light coat of 574 loc tite will work fine, even blue 242 will work in a pinch.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-29-2008, 05:55 AM
356RS's Avatar
Thank You Mike.
Mark Jung
Bend, OR
MFI Werks.com
Old 01-29-2008, 09:59 AM
