-   -   What do I do with my Alusils? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/390764-what-do-i-do-my-alusils.html)
adelis 02-03-2008 08:24 AM
I have a set of Alusil cylinders and Mahle pistons with 76k from an '87 3.2. No damage that I can see, but I have not measured them and there are no rings on the pistons currently. They were replaced by a set of 3.4 P&Cs from Supertec. So what do I do with the Alusils? Do they have any value at all? I am headed to the dump tomorrow and I don't mind taking them with me if that's what it comes to. Thanks.
Eagledriver 02-03-2008 08:49 PM
There are some people who would re-ring them and use them if the ring lands are ok. You could put the used parts list. If the ring lands are in spec they could be worth a couple hundred dollars. If the lands are out of spec then they are basically worthless.
-Andy
adelis 02-04-2008 04:45 AM
-Andy
Thanks for the response. I will give that a try.
tom1394racing 02-07-2008 08:42 AM
Your 3.2 Alusil cylinders can be bored and replated. I've sold several sets of 3.2 Alusils on the board.
dtw 02-07-2008 09:12 AM
EBS buys Alusil cylinders.
Crashly 02-07-2008 11:04 PM
easure them and if they are within spec thay can be reused. You may need to ship them to a machine shop that specifically cleans and has the specific tools to hone the alusils.
Jeff Alton 02-07-2008 11:17 PM
They certainly have a core value to folks who bore them to 98mm. Call EBS and see, but I guessing in exess of 400.00.... Same is not true for 95mm SC cylinders.
I have re ringed a couple of sets of alusil with success, as have others, but I still feel it is a crap shoot.
Cheers
adelis 02-07-2008 11:46 PM
Thanks for all the replies. I don't want to reuse them, I want them to go away! A deal is in the works.
