What do I do with my Alusils?
I have a set of Alusil cylinders and Mahle pistons with 76k from an '87 3.2. No damage that I can see, but I have not measured them and there are no rings on the pistons currently. They were replaced by a set of 3.4 P&Cs from Supertec. So what do I do with the Alusils? Do they have any value at all? I am headed to the dump tomorrow and I don't mind taking them with me if that's what it comes to. Thanks.
--Angelo Delis-- 1987 Carrera Coupe GP White 2006 Tundra 2003 Audi A6 Quattro 2.7T 2000 Audi TT 1.8T |
There are some people who would re-ring them and use them if the ring lands are ok. You could put the used parts list. If the ring lands are in spec they could be worth a couple hundred dollars. If the lands are out of spec then they are basically worthless.
-Andy
72 Carrera RS replica, Spec 911 racer |
Your 3.2 Alusil cylinders can be bored and replated. I've sold several sets of 3.2 Alusils on the board.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
GAFB
EBS buys Alusil cylinders.
Several BMWs |
easure them and if they are within spec thay can be reused. You may need to ship them to a machine shop that specifically cleans and has the specific tools to hone the alusils.
They certainly have a core value to folks who bore them to 98mm. Call EBS and see, but I guessing in exess of 400.00.... Same is not true for 95mm SC cylinders.
I have re ringed a couple of sets of alusil with success, as have others, but I still feel it is a crap shoot. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks for all the replies. I don't want to reuse them, I want them to go away! A deal is in the works.
