Jet and Choke sizes doable on my new engine?
Hello and thanks for your replies in advance.
I am looking at buying a set of carbs that have the following venturi's and jets. Will these work well for my 2.7 with 9.8:1 compression ported to 38/36and GE 40 cams? size: 40 AV's: 4.5 Vens: 36 Mains: 145 Idles: 55 Idle airs: 130 Airs: 190 Tubes: F11 FBCV's: 50 Fittings: HB |
I think those will be close. The venturi size is perfect. You might need to open up the mains to 150 or 155. I don't have alot of experience however so expert advise might help. LM1 or a trip to the dyno will dial it in.
-Andy |
| All times are GMT -8. The time now is 10:36 PM. |
