Cylinder base gasket sealer?
Waynes book says locktite 574, I read here curil-t. Consensus opinion?
Try not, Do or Do not
Curil-T
If there is an issue with tolerances, we use ThreeBond 1211.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Curil-T....
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Don't use the 574 or any other hardening sealant. It will harden before you've torqued all the heads and then you will have a hard layer of variable thickness on each cylinder. Curil-T is fine as is any non-hardening sealant such as non-hardening permatex. They can also be installed dry like the factory did.
-Andy
72 Carrera RS replica, Spec 911 racer |
3.4 Bigger is better
I used this as per John Walkers recommendation, K&W Copper Coat. No leaks three years later
![]() http://www.crcindustries.com/auto/content/prod_detail.aspx?PN=401612&S=N
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport Last edited by 88-diamondblue; 02-09-2010 at 02:13 PM.. |
