Sigurd's Avatar
Max RPM
I'm currently building a 2.7 with JE pistons, CIS, and 964 profile cams. What maximum rpm should I plan for on this motor? Maximum meaning occasional, not constant.
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 02-19-2008, 07:38 AM
The first limitation is the valve springs. With stock valve springs and retainers you should not exceed the stock 964 rev limit. I don't know what that is, but probably around 6500. The bottom end is good for 7000 with occational trips to 7500. With stiffer valve springs and/or titanium retainers the valve train will be good for 7500 or so.
-Andy
Old 02-19-2008, 10:36 PM
Sigurd,
964 cams have peaked by 6500 RPM so running the engine beyond that simply constitutes abuse,....
Re-gear the car to always keep the RPM between 4500 & 6300 at each shift and you'll be just fine.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-20-2008, 12:55 AM
