304065's Avatar
Questions about 1980 SC engine
Another question inadvertently posted by "Transformer."
I am in the process of rebuilding a 1980 911SC engine. Has anyone used Delta cam for repairing a cam lobe and rocker arms?
Also how do you pressure test an oil cooler ? and its it OK to use the #8 bearing over , this engine has 50k miles and the rest of the bearings look good
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-27-2008, 06:08 AM
Haven't heard of Delta cam. You pressure test the oil cooler with compressed air. Most people make a fitting up out of a block of aluminum to seal the holes and fit a shrader valve (tire valve). You pump up the cooler to 100-150 psi and submerge in water looking for bubbles.
Number 8 bearings are usually reused. You need to evaluate for excessive wear or damage.
-Andy
Old 02-27-2008, 11:02 AM
abit off center
cgarr's Avatar
Make sure your #8 is very good, Thats where your rods get a lot of there oil!
______________________
Craig
G2Performance
Old 02-27-2008, 11:39 AM
