Provide HP numbers for a 3.0L biuld
Here are some toys and tricks that I thought would deliver the best HP for a 3.0L rebuild can any give me HP numbers for a build like this:
Mahle Pistons 98mm
PMO 46mm
CAMshaft S
SSI EXHAUST
Quasi diff 43 teeth fine spine
Twin plug distributor
This would cost 18K just for the parts. The Mahle pistons I would have to order from God.
Old 03-01-2008, 10:17 AM
jluetjen's Avatar
I don't think that an "early S" cam shaft is really going to give you the lift that the engine could use -- especially if it's an early SC with the large ports. I think that you'd do better with GE60's.
I'm guessing about 241 HP at 6300 RPM and 199 lb-ft of torque at 5100 RPM.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-01-2008, 05:29 PM
rsscotty's Avatar
HP numbers
I think that engine should do at least 270 hp at the flywheel. That number may be a bit low depending on exhaust and comp. ratio. The SSI and muffler combination could result in less power. We use 1 5/8 Georges headers.
I have dynoed similar engines with stock cams and EFI that do 260-265 with no problem using headers and race muffler.
Old 03-01-2008, 05:57 PM
Loose nut bhind the wheel
What is this?
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 03-02-2008, 07:39 AM
jluetjen's Avatar
Oops. I forgot to take into account the 98 mm pistons. My corrected estimate agrees with Rscotty: 270 HP at 6300 and 220 lb-ft at 5100 RPM.
John
'69 911E
Old 03-02-2008, 11:41 AM
