Port size for a 3.2ss
I am planning my engine build and wanted some advice on what size ports I should run.
It will be(so far) 3.0 case and crank 3.2 cylinders bored to 98 JE 9.5:1 pistons DC40-mod's' cams Webers headers single plug Heads are currently later 34 intake with 35 ex. ports. I want to open them up some, but don't know har far to go.
Donnie Currently Porsche-less.....
I would rather be driving
Open them up to the early SC size - 39mm This will put your port velocity at the peak range of around 105 m/sec at 7100 rpm (peak HP for Mod_s). Anything much faster than 100 m/sec will not flow enough and you want to maximize port velocity. Also, larger port sizes will be restricted by the carbs on top. I recall you are using weber 40s. Don't forget to match the carb manifolds to the heads.
thanks to John Leutjen for this velocity calculations.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
