Anarchist Extremist
Cam timing? 3.0sc cis w/964 cams
What timing should I use for a 964 cam-ed CIS 1980 SC? I am thinking I should follow timing for the 1978-1980 R.o.W. 911SC, but mayne some tuners out there have a better idea?
thanks for any input. Chris
80 SC Coupe 00 Tundra (Tow Rig) 00 Audi A6 Avant (wifes rig) 03 Wife ('71 typ Spezial) 05 Kid (MENSA prototype) |
I think you should use the timing from the 964 engines. There is a plus or minus to that spec and you can go to one end or the other depending on what you want. If you still have the small ports (34mm) I would go on the advanced side. If you have larger ports then I would go on the retard side. Sorry I don't know what the 964 spec is.
-Andy
72 Carrera RS replica, Spec 911 racer |
Capitalist and Patriot
You might check with pelican name "Jeff Alton" he's built a couple of these 3.0 w/964 cams and seems to know his Porsches...
Good Luck, this is my next "major" project, so I'm taking notes!
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
1.26mm.
Same as 3.2 Carrera (1.1mm to 1.4mm) This came from EBS for 964 re-grind cams. CIS car ran great at this setting with lots of torque. Lyn
Track: 91 C2 SuperCup wannabe, 08 Cayman S Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange |
I have set these at 1.26 in the past with both the 3.0 and 3.2 motors and been happy. I have not experimented with advancing or retarding them with in the spec range to see if there was any differnce to be noted.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Talk to Elgin Cams
I have 964 cams in my 81SC and I think it could use some more low end power. It pulls like mad up to 7,200 rpm. I think I am going to retard the timming 2 degrees.
Kenneth Silver 81' Targa |
I ran a set of Elgin SC sports recently. I had to ask him for the specs, and he replied "2mm". I've heard this grind is similar to the 964.
Jon |
-Andy
"The 964 and the SC improved stock or the sport SC. The sport sc is timed @2.0 mm with 0-lasssh the 964 is timed by the factory .004 lash @1.26mm lift at lap. I always like to advance the cams a few degrees for more low end responce. I hope that this helps. Dimitri"Dema"Elgin"
Anarchist Extremist
Kenneth, So by advanced you mean what. 1.31mm is that OK or more...? I dont know what a sport SC is I dont believe I have one it is a stock 1980 (did come with sport seats) with the small port heads and CIS. I have read about the 964 cam upgrade, so I went ahead and bought a set. could you please expand on this subject? I am thoroughly interested.
thanks Chris
I did this exact timing 2 months ago: 1.26mm
My engine was a 78 ROW 3.0L with 964 camshafts regrind.
Red 911 SC euro 78 - 964 cams, Carrera tensionners, new steel head studs, SSI & dansk 2 in 1 |
Anarchist Extremist
so you got it exact? 1.26 or were you .10 either way. I found it almost impossible to get it exact so I settled with 1.3 and 1.31.
Chris
up-fixing der car(ma)
That will work fine. Now just check your valve clearance (piston-to-valve) and double check your valve adjustment (elephant foot to valve) and confirm your cams are installed on the proper sides of the engine. These are easy enough mistakes; seems common anyway.
Cheers, Scott
Scott Kinder kindersport @ gmail.com |
Anarchist Extremist
ytnukler, cams double checked (rabbit right) .004 on foot as per SC gap spec. Piston to valve aint done that, but Jerry Woods taught that we could use solder, I didnt think it was even possible to have valve clearence issues with a US SC with CIS, unless I was a complete idjut, as the CU is so low. thoughts? should I even bother, most say no, you?
Chris
I've never seen it that close on SC's, enough that I would have to worry or do something about it.
I always just do it, just in case a customer asks or ...for whatever reason I need that data later.
