Will 2.7 heads fit a 2.4?
It looks like the bore dia. is ~.25" difference, so I'm concerned about that fitting up right. Working on SVRA spec race car, and 2.7 displacement will bump me up a class, I'd rather stick with the 2.4 for now, but was thinking the 2.7 might be a little better head+ give me a 2nd set to send off for machining etc.
Old 03-16-2008, 06:17 PM
MarKoBrow's Avatar
I always thought the heads were the same. I think the port sizes might be different.
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 03-16-2008, 06:45 PM
2.7/2.4 heads
The heads are interchangable, but the chamfer on the 2.7 is for a 90mm bore and that will gain some head vol., if we use those for smaller bores they get welded and remachined, another tip is to weld up the huge spark plug relief area or reduce them to 12 mm plugs, other than that the valves are the same size, the ports will vary from year to year and they are an easier head to find.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 03-17-2008, 05:40 AM
