Early AL case w/3.2 oil pump, sump cover?
I'm in the process of rebuilding my early Aluminum case and have installed a 3.2. oil pump. Is there a special sump cover that would fit in this application? is appears that the scavange side of the pump sticks out too far.
Thanks,
Nabil
'71 S track car, 2.7L & Webers forever!
Old 03-21-2008, 06:36 AM
356RS's Avatar
Yes....Get yourself the later sump cover. I believe that plate started in 1982 or so with the introduction of the larger pumps with the pick-up screen. Your host has them in stock.
Mark Jung
Bend, OR
MFI Werks.com
Old 03-21-2008, 07:55 AM
'Supertec Performance a regular contributor on this board, sells a very nice finned cast aluminum sump cover for people who have put late oil pumps into early cases it looks right with the finned cast aluminum case and has the clearance needed and a drain plug. Fritz
Old 03-21-2008, 09:11 AM
Thanks Fellas, I was just placing a supertec order so that works great!
Nabil
Old 03-21-2008, 09:33 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-21-2008, 04:48 PM
