3.2L longblock missing throttle body: what's the best answer
I just picked up a 3.2 Carrera longblock without the injection throttle body and a few other parts. It is going to replace a chevy 350 in my 914 (ebay special). Since it doesn't have the throttle body now but did come with a megasquirt, is there an easy answer to fix my fuel problem e.g. does anybody have preferences/recommendations for one of the following over the other:
1) buy the throttle body. I will also have to replace the fuel pump, fuel systems etc. this might be the cheapest.
2) buy webers (I know them well). Will 40s work and is there a known good setup for the 3.2? Does anybody have a good experience with this that will avoid popping, snapping, hesitation, flat spots, etc.
3) try to fix a megasquirt that is coming with the engine? it wouldn't idle for the previous owner so he wasn't happy with it.
any and all comments, recommendations, feedback is greatly appreciated.
thanks
marlin
Marlin Ness
sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8
currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera
Old 03-25-2008, 07:36 PM
3.2 CAB's Avatar
Hi Marlin, did the 3.2 come with all of the DME control items? Just how much of the intake is complete? What type of transmission are you going to be using? It sounds like you are going to be doing some quality rebuilt or used parts shopping. PM me if you want. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-25-2008, 10:24 PM
3.2 intake best answer
Have been traveling 100% since the last post, finally got to look at the package I got and discovered the following:
1) no intake at all
2) DME or an MSD 6A set up
3) both styles of exhaust are possible
I also got a late 80s 915 with LSD 8:31 with a flipped ring and pinion since this is going in a 914. very high fifth gear because it was connected to the V8.
I am familiar with Webers. Will Webers work with a 1987 US spec 3.2? 40s or 46s? Can 40s be made to work? Is this a proven combination? Or do I need to go with the DME stuff?
Any and all recommendations will be greatly appreciated to make this run right.
thanks in advance
Marlin Ness
Old 04-22-2008, 07:10 PM
North Coast Cab's Avatar
If you have the DME and all the wiring purchasing a full Carrera intake set-up is probably your best bet. SB around $750 complete, although prices have been rising.
Carbs are the bomb in my book, but 40's are way too small for a 3.2 Probably looking at a minimum 46's if not 50's. They are impossible to find used so you are looking at $3k+ new. If you go that route you will have to ditch the DME set-up, sell for $$, and switch to a dizzy-less ignition or MSD/dizzy set-up. Mayeb sell the Mega set-up too to recover some cash. you'll need to address fuel pump fuel filters and a few other items too.
All depends on what you want in the end. I would detail the options so you knwo what your;e in for before you get started. Couild get very expensive quickly.
1985.5 944 GTS
Old 04-23-2008, 06:17 AM
46 Webers on 3.2
thank you very much for your answer. I have a line on a set of 46 PMOs for a reasonable price. Has anybody used 46s on a 3.2 with out any other changes to the longblock? Is this viable? or do I just need to buy the standard intake which appears to be the safest choice (although I would have to do a bunch of work with the fuel pump, fuel lines etc to make this work in a 914.
thanks in advance
Marlin Ness
Old 04-25-2008, 06:39 AM
