Need help on a 993 cam choice....
Need some advice on cam selection for a hot 993 motor. Motor will be:
3.8 10.5ish:1 CR (actual not stated) 1.75 primaries 50mm ITB's Solid rocker conversion Programable ECU Now comes cam choice. I want to have a redline around about 7300-7500 (but would still be okay with a 7000 redline)and still want some decent bottom end grunt. Motor will power a 2225lb car. (or maybe a racecarreplicas.com 917) Looking for a fairly wide power band, emissions not an issue. What kind of power can I make with this? 350? 375? Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 03-31-2008 at 09:26 PM.. |
Jeff, I have a nice set of used 3.8 RSR cams from
webcam, not sure if you have any interest. Jim jdorociak@gmail.com |
I may indeed, need to do some more research!
I also may need the fan and alternator you had advertised! Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
