Jeff Alton's Avatar
Need help on a 993 cam choice....
Need some advice on cam selection for a hot 993 motor. Motor will be:
3.8
10.5ish:1 CR (actual not stated)
1.75 primaries
50mm ITB's
Solid rocker conversion
Programable ECU
Now comes cam choice. I want to have a redline around about 7300-7500 (but would still be okay with a 7000 redline)and still want some decent bottom end grunt. Motor will power a 2225lb car. (or maybe a racecarreplicas.com 917)
Looking for a fairly wide power band, emissions not an issue.
What kind of power can I make with this? 350? 375?
Cheers
www.turn3autosport.com
Old 03-31-2008, 06:49 PM
Jeff, I have a nice set of used 3.8 RSR cams from
webcam, not sure if you have any interest. Jim
jdorociak@gmail.com
Old 03-31-2008, 07:48 PM
Jeff Alton's Avatar
I may indeed, need to do some more research!
I also may need the fan and alternator you had advertised!
Cheers
Old 03-31-2008, 07:56 PM
