Rocker Arm Shaft Question
How much wear is considered acceptable for the rocker arm shafts? I was disassembling my heads last night and was surprised at the amount of scoring that I noticed on my shafts. Is this considered "normal" wear? Thanks in advance.
Mark 1987 Carrera 2018 GMC Sierra Denali 2500 Duramax 2012 Harley Davidson FLHX Street Glide |
Air Medal or two
I am thinking anymore then a shadow would be too much
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
You can measure the outer diameter with a caliper. I recall mine were 18.02 mm, surprisingly all of them were. There are tolerances mentioned in Wayne's book.
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
Air Medal or two
I would be concerned for reason for the "wear"
I consider more than .0003" unacceptable.
John Dougherty Dougherty Racing Cams |
Wow, 3 10thousandths! My micrometer isn't that good, but no wonder they were all 18.02. Thanks camgrinder.
Well, I don't have a spec book for an '87. You should absolutely have one, or the factory workshop manual, to guide you through all mechanical work.
My old book for the '65-68 cars says the specs are: Rocker arm shaft: 17.992-18.000 mm So the difference is 0.008mm, or 0.00031496063" (which is exactly what Camgrinder said, 'cept in "English." )The rocker shaft bore in the cam housing is listed as 18.000-18.018.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Some scoring seems to be common on the shafts. That doesn't mean they are worn out. You can check with a micrometer. I install them with the scored surface on the "outside" so the smooth surface wears for the second life of the engine. Worn out rocker arm shafts and bushings will be noisy. Not dangerous but annoying.
-Andy
72 Carrera RS replica, Spec 911 racer |
Thanks for the input. I'll "mic" them tomorrow and see where I am at.
Anything wrong with Eagledriver's process? Aren't these under pressure from the "bottom" only?
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
