Compressing Mechanical Tensioners
I am currently trying to replace an early type tensioner in a 3.0 SC engine , and am having problems with compressing the unit.
I have done several hydraulic tensioners in the past , with no dramas - but I think I am doing something wrong here!
I bought the bent metal clip from our host here , as I understand this is the best method to keep it in the closed position , and duly compressed the tensioner in a vice - there was a lot of resistance , but it did close up sufficiently to get the clip on.
Returning to the bench a couple of hours later , I found the tensioner sitting in a pool of oil , and on removing the clip , was able to compress the piston with finger pressure only - obviously I have wrecked it
Can anyone tell me what I might be doing wrong before I destroy another one?
Many thanks
Mark
Old 04-07-2008, 01:46 AM
Bump for some qualified thoughts about this.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 04-08-2008, 07:51 AM
safe's Avatar
compress it very slowly, if you didn't.
Magnus
Old 04-08-2008, 12:08 PM
abit off center
cgarr's Avatar
I could be all wrong here but, if you keep a steady pressure on them they should compress, the oil is only a buffer to keep them from quickly collapsing, I believe the screw in the side will release the pressure? I have pumped them back up with a supply of oil on top and I guess thats how they stay full when in use, there is a check ball inside which will let oil in but not out when pumped up.
______________________
Craig
G2Performance
Old 04-08-2008, 12:29 PM
Thanks !!! - I didn't ! - now I have , and it works perfectly.
Where would we all be without this board - Thanks again
Old 04-08-2008, 12:49 PM
I'm not sure the route to recovery/repressurizing is through the check ball. If you depress the check ball, oil escapes. On the other hand, I don't think it will naturally allow oil back in.
You can depress the check ball by removing the uppermost retainer and seal. From there, you can slip a paper clip down the plunger to depress the check ball. That's as far as I've gotten in messing around with one out of a pair of spare tensioners I have (I carry them in my spares kit when I travel). It was leaking oil, so I disassembled the top part and found a shot O-ring. I plan on rebuilding both, but I haven't gotten around to ordering the rebuild kits for them.
Compare a properly filled 930-type tensioner to one that has lost a portion of its oil -- it highlights the incompressibility of a fluid to the compressibility of a gas. There shouldn't be any air inside a properly functioning tensioner.
The workshop manual and Haynes have procedures about re-filling and bleeding while mounting the tensioner at a 20-degree angle in a vice (working from memory here).
Brian
'82 SC Targa
'83 SC Cabriolet
Old 04-08-2008, 01:06 PM
How did you replace the lost oil?
Brian
'82 SC Targa
'83 SC Cabriolet
Old 04-08-2008, 01:07 PM
thesey914's Avatar
Compress it in a vice - see my sig for a "how to"
Rebuild your 911 tensioners
Old 04-09-2008, 08:08 AM
sudo apt-get purge 930
equality72521's Avatar
You don't have a sig.
--clutch-monkey
Old 04-09-2008, 08:50 AM
notmytarga's Avatar
http://www.thesey.com/tensioner.html
I found the link in his profile - nice write up with lots of clear pictures.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 04-09-2008, 09:32 AM
Ok, got it.
--clutch-monkey
Old 04-09-2008, 09:58 AM
thesey914's Avatar
whoops forgot to tick sig box
Old 04-09-2008, 03:42 PM
