-   -   Why doesn't Pelican sell this? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/403524-why-doesnt-pelican-sell.html)
SlackeR32 04-12-2008 05:32 PM
Firstly I'm sorry for double posting this (also in the 911 tech section), but I'm in a jam, and if it helps I've already bought and read 2 of Waynes books. Does everyones rebuild/modify book come autographed? Thanks Wayne. :D
I'm in the process of redoing the oil cooling on my 914 3.2 conversion. I'd like to remove the on-engine cooler and replace it with a larger after-market unit. I've seen a plate which bolts in this location and provides two AN-16 (or similar) fittings to run hoses to the new cooler, but I cannot for the life of me find it now. Smart racing comes the closest with a kit to relocate the oil filter to this area, I could then run a more standard oil filter relocation kit from there but the correct plate would be a much nicer solution.
I really need to get this peice in a hurry and will be extremely grateful for any help. Thank you!
Also feel free to debate the merits of this idea as it bumps my thread and I may then find the part sooner. ;)
onboost 04-12-2008 05:50 PM
I know the piece you're talking about but can't remember where I saw it either. Did you check with Patrick racing in AZ or BAT in FLA?
SlackeR32 04-13-2008 07:27 AM
Thak you. I've been all over their websites but will have to call both of them on Monday to be sure. I'll call Smart racing as well. I'll give Pelican the first call though just in case.
dad911 04-13-2008 05:49 PM
I think that it is a 'factory' part from a 3.6..... 964 or 993.
correction.... 930.107.205.1R - is the part that replaces the engine oil cooler with an oil filter/blockoff. I think we used machined adapters to go from the AN fittings to the feed and return lines.
