Addicted to Racing
edbaus's Avatar
oil pump questions
I have a bad 964 oil pump. The housing is cracked.
I also have a box of 930 oil pump parts. (a race motor came apart and the rod went though the top of the pressure housing)
Are the parts interchangeable. Can I use the scavenge housing from a 930 on a 964 pump.
Or, are these things precision made so I need to keep an oil pump together as a set, so I can not even interchange parts from two 930 pumps.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 04-16-2008, 11:51 PM
MBEngineering's Avatar
HI Ed
did the 930 oil pump parts I sent you over fit the pump you have?, I have a 964 pump hear with a bent shaft and good cases if it is any good to you it could be sent AIR mail asap, which case is damaged on your pump.
the 964 pump has a smaller pressure side at 43mm and the turbo is 51mm,(GT3 is 51mm)
I put this together for the photo and the bolt holes fit and shafts, the only thing I could not do is to check for rotation as the pump I used is to one with the slightly bent shaft.
hope this is of some help?
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 04-17-2008, 01:59 AM
