-   -   Joe Gibbs Oil (http://forums.pelicanparts.com/911-engine-rebuilding-forum/405741-joe-gibbs-oil.html)
Cupcar 04-24-2008 11:37 AM
Joe Gibbs Oil
Joe Gibbs racing offers synthetic oils. They are represented to be high in ZDDP etc.
Anybody use these in their air-cooled 911 engines?
http://www.joegibbsracingoil.com/hotrod/index.html
http://www.joegibbsracingoil.com/products/engineoils.html
911pcars 04-24-2008 12:29 PM
8$ a quart. Hmmmm. Do you get what you pay for?
Sherwood
1982911SCTarga 04-24-2008 12:41 PM
What does Gibbs say about it? "Up here you need an oil that will fight hard and lube its guts out"?
Brian
cnavarro 04-24-2008 05:12 PM
If you look at the msds for the 15w50, it has a flash point of 386.6F, which is very low, especially given it's a synthetic. It smells of marketing to me...
Also:
"From 0.5 to 1.5 percent zinc compounds; contains 0.1% as Zn."
cstreit 04-25-2008 07:53 AM
I actually carry the stuff, but honestly am suspicious as well. I haven't seen any evidence of serious testing or analysis. They've written that this is forthcoming but that's been a long time.
cnavarro 04-25-2008 03:37 PM
Just like Danica Patrick "Peak" (same brand as the coolant) Motor Oil. Just because she's on the bottle, doesn't mean it'll perform :-)
MBruns 04-28-2008 11:28 AM
JGR oil
We have used this oil in our 911 race car for the last 2 years and have had it
apart to freshen before this season and it was very nice, actually one of the first 911 race engines where you could have re used the rod bearings, the engine had almost 40 hours and it cracked a cyl head, it is a 3.8 making just over 113 hp per liter. we use the break in oil on the dyno with great results, the customers that have used it all have had positive results.
Mike Bruns JBRacing.comhttp://forums.pelicanparts.com/uploa...1209407311.jpg
eddie914 04-28-2008 11:43 AM
What about Brad Penn Racing Oil?
It is rumored to be the same formulation as the "old" Kendall GT-1 "green" oil.
Does the high ZDDP give it the green tint?
Eddie
