Silly Engine Questions Thread
oK, let me start. I've got Wayne's book. I see mention of a motor with 2.7 crank in the 3.0 case. Is there any way to use the 3.2 Pistons/cylinders with the 2.7 crank in the 7R case? Could you just shorten the cylinder?
I've read many pages of this forum..no mention. Obvious newbie wonders.
WARNING: Do not buy from Ron Kirby of Fort Thomas, KY (currently RRRacing1970).
Old 05-11-2008, 08:38 AM
356RS's Avatar
The 3.2 has 95mm piston/cylinders and will not fit the 7R case. The biggest piston size that can be fitted into the 7R case are from LN Engineering and they are 93mm and that's pushing it to the max.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-11-2008, 09:22 AM
Thank you for the info. Is it more a bolt spacing issue or strength issue?
Old 05-11-2008, 02:48 PM
It has to do with the size of the hole in the case that the rods stick trough, the round opening between the 4 studs.
You would have to grind them larger but I would not recommend doing that ...
Better a good one for a lot of bucks, than a bad one for little
Old 05-11-2008, 04:02 PM
OK... Next question.
If that just has to do with spigot size/case strength rather than bolt spacing, then question number two is "Can SC heads be used on smaller bore cylinders?"
Old 05-12-2008, 12:40 PM
dtw dtw is offline
GAFB
No and no. The head stud spacing changed on the SCs and up, so jugs/heads from 3l motors cannot be used on the 2.7 cases, and vice versa.
Old 05-12-2008, 01:45 PM
Actually, I'm finishing up a set of cylinders special made with the case register of a 2.7 and head register of a 3.0/3.2, to allow for later heads. The customer is going to modify the heads to fit the 2.7 stud pattern, as it's actually pretty close and quite feasible and not all that expensive to do. It was actually the customer's idea and not a bad one at all!
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 05-12-2008, 07:25 PM
Let me test a set!
Assuming that's a no, on to question III:
I'm obsessed with implementing megasquirt. The plan was to use some 3.2 Intake stuff I've sourced and port the heads to match. Will this kill air velocity? This is not intended to be a track car--just some track days. I realize that there's a lot of other stuff at play here, but is this a very bad idea?
PS: Thanks to the board for entertaining questions from a newbie.
Old 05-12-2008, 07:31 PM
Free minder
Aurel's Avatar
Here is a silly question for the thread: could one build a 3.3 NA motor from a 3.0 case and 3.3 turbo cylinders with higher compression JE pistons?
Aurel
Old 05-12-2008, 08:53 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Aurel
sure
Scott Kinder
kindersport @ gmail.com
Old 05-13-2008, 02:29 AM
TibetanT's Avatar
I am no expert in this area, but I think the 3.3L engine has the same case as the 3.0L 911SC, right?
So, if this is true...you should be able to do it.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 05-13-2008, 11:16 PM
