-   -   C2 Cylinders/Head Seepage (http://forums.pelicanparts.com/911-engine-rebuilding-forum/409227-c2-cylinders-head-seepage.html)
WERK I 05-14-2008 05:39 AM
Do any of you remember the problems with some of the C2 cylinders/heads seeping oil? I know there were only a small percentage of engines with the problem but I was wondering if any of you recall how it happened. Was the the heads, the cylinders? :confused:
sand_man 05-14-2008 06:15 AM
The only thing I can remember was that (I *THINK*) a special gasket/o-ring needed to be used with the cylinders.
JeremyD 05-14-2008 07:01 AM
Heads to cylinders - Porsche bulliten states that if the area is wet to the touch - they need to be addressed.
The solution is new P & C's - although I think that Ollies is now machining in a later sealing groove.
http://forums.pelicanparts.com/uploa...1210777268.jpg
http://forums.pelicanparts.com/uploa...1210777301.jpg
Steve@Rennsport 05-14-2008 09:51 AM
Dave,
The leakage was due to lack of sealing rings between the heads and cylinders. Late, replacement cylinders had a groove for a gasket and the heads can be machined to suit.
We've had really good luck machining those early heads for a sealing ring and them modifying the tops of the existing cylinders to fit. After 20+ sets over the past 6-7 years, nary a leak. :) :)
Jeff Alton 05-14-2008 09:59 AM
I had one of those sets Steve speaks of, working great!
Cheers
racing97 05-15-2008 07:14 AM
Originally Posted by Steve@Rennsport (Post 3942034)
Dave,
Steve, if it isn't giving away some proprietary situation, I am intrigued how after surfacing the heads out to the later barrel specs you can reuse the barrels.
I respect that kind of ingenuity. Once again if you don't mind a picture would be cool.
Steve@Rennsport 05-15-2008 07:26 AM
I don't have any pictures but we machine the heads for the later sealing rings and put a small bevel on the top edges of the cylinders to exert pressure on the rings.
Works great. :)
ischmitz 05-16-2008 01:08 PM
I run a set of "early" C2 barrels machined by Walt from Competition Engineering. They were a warrantly replacement. He machined a step into the top sealing surface and I put a fire-ring in from the Turbo. The engine is leak-free for 20.000 miles now and I am very happy with that. Mine were leaking a lot before and were unsalvageable. They went out of round.
Ingo
