-   -   Con Rod Nuts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/410795-con-rod-nuts.html)
88911coupe 05-22-2008 07:34 PM
Con Rod Nuts
I've ordered new con rod bolts from our host but planned on reusing the nuts....is this acceptable or not?
TIA
Henry Schmidt 05-22-2008 09:02 PM
Reusing the rod nuts won't hurt, but why would you ? A 911 engine rebuild is a gamble at best. Why cut corners?
We carry rod nut replacement one step further. We use the serrated flange 928 nut with all new bolts, even ARP and ty bolts.
@ 2.50 ea it seems like the best choice.
http://forums.pelicanparts.com/uploa...1211518844.jpg
Porschekid962 05-22-2008 10:19 PM
Reusing rod nuts? No thank you, no need for Ti nuts either. Plus using a Ti(tanium) nut on a steel bolt is not the proper thing to do, those metals dont like each other that much. ARP is one of the better fastener companies, stock will always work but buy new ones. I hear of people dropping a lot of money on all the wrong stuff and then want to reuse rod nuts or flywheel bolts or this or that. Just replace it.
ajwans 05-23-2008 05:17 AM
I'm about to buy a set of ARP connecting rod bolts for a 2.0S rebuild.
Is there an option for metric nut sizing, I know it'll probably never
come apart again but it just seems wrong to stick imperial sized
rubbish inside a beautiful machine.
andy
304065 05-23-2008 05:43 AM
Buck, I would get new nuts, the threads fatigue too, and the facets of the nuts may be rounded if you look very closely.
Andy, you are exactly correct. As I was assembling my engine I noticed that a metric socket didn't fit around the ARP nut. The bloody thing is SAE! That's like white socks with a suit, how can anyone produce a metric sized bolt (10mm) with an SAE nut? There is absolutely no reason for it.
Henry Schmidt 05-23-2008 08:19 AM
No one was recommending Ty nuts on steel bolts, although if properly coated they will work fine. What we recommend is the Porsche 928/944 rod nut (steel, serrated, flanged) on all 10 mm Porsche rod bolts. Even Ty and ARP bolts. They are of the highest quality and offer a serrated flange for better stability/reliability.
They also have a 14 mm head and are far more cost effective than ARP nuts.
928 103 172 02 msrp $ 1.86
As I stated above, the 928 /944 rod nut (12 point 14mm head) will fit the ARP10mm bolt ( 2.0, 2.2, 2.4, 2.7, 3.0 and GT3) and the ARP bolts can be purchased sans nuts at a greatly reduced price.
RSstop 05-23-2008 08:31 AM
Weight?
Henry,
Is there any weight savings? Probably not much, but didn't know if that was a driver in using these.
Lyn
Henry Schmidt 05-23-2008 08:52 AM
There is no weight savings. In fact the 12 point nut actually weighs 2 grams more. The reason for using them is the quality. Higher quality/ low price equals good investment.
88911coupe 05-23-2008 09:20 AM
My main reason for asking was b/c I was probably going to start the reassembly this weekend and there was no way I'd get them from Pelican in time, but I can just buy them locally now that I think about it. I've been so brainwashed by the Pelican Kool Aid I forget sometimes I can buy parts here in Dallas....D'OH!
Porschekid962 05-23-2008 07:00 PM
Henry im just figuring on a streetcar the Ti nuts in any form would not be the right choice. I like stock and I like arp, just depends on your application.
Guys, SAE fasteners are some of the best out there, AN and NAS are in prolific use throughout all kinds of racecars. Metric is pretty much for motors. ARP makes some of the best aftermarket fasteners you can buy, its probably also the biggest name in the public. You can always call up Coast Fabrications and they can have custom bolts made for you but open wide...
mcinturff 05-24-2008 09:41 PM
If titanium is strong enough to be used for con rods it will certainly hold up to the stresses of rod nuts.
Flieger 05-25-2008 08:39 AM
The issue is not strength as far as breaking is concerned. Titanium nuts on steel studs or wheel hubs have a tendancy to "creep". The factory used steel nuts on 917 Dilavar studs for the same reason. They tried Titanium on wheel nuts but found they backed off during a race, if I remember Fere's The Racing Porsches correctly.
Titanium does not break, it just flexes and heats as it expands and lets go of its clamoing force.
Correct me if I am wrong:)
sww914 05-25-2008 10:56 AM
Nobody suggested using Ti nuts. Henry said that he uses the 928/944 STEEL NUTS even on Ti bolts. STEEL NUTS.
mcinturff 05-25-2008 11:58 AM
has inconel ever been used in a Porsche motor? I know F1 cars use it for exhaust due to better heat retention properties than steel and especially aluminum.
ajwans 05-25-2008 06:34 PM
Henry, how could somebody go about ordering ARP bolts without the nuts? I am in Australia.
I have only seen the nut+bolt kits online, is there a part number for a special order?
andy
TimT 05-25-2008 07:17 PM
Yes, I have a set of 935 headers made from iconel. Not a fastener....
mcinturff 05-25-2008 07:32 PM
i'll bet you had to shell out a few bucks for those, eh? How is the quality?
TimT 05-25-2008 07:39 PM
How is the quality?
Suberb... the welds are impressive, all the flanges live in the same plane, and the turbos mount right where they should........
I have some pic (somewhere), but then this is a thread about fasteners.... not exhausts..
Wayne 962 05-26-2008 01:51 AM
A marketing guy I used to chat with told me that your goal is to not to make your company the preferred choice, but instead in the customer's mind to make it the *only* choice they ever think of. Mission accomplished here!
-Wayne
