Free minder
Aurel's Avatar
Ignition timing with DC15 cams
I need a bit of advice here,
So I rebuilt my 3.0 motor with DC15 cams, and I got it started. I set the ignition timing to 5 deg past TDC, but it does not run right like that. The motor dies if I open the throttle wide. I was wondering if DC15 cams require a different ignition timing?? Note that this could be another problem, like a spark plug not firing, or an injector not spraying well, but I`d like to know if 5 deg past TDC work for these cams first.
Aurel
Old 05-23-2008, 08:52 AM
Is the timing really set after TDC? Usually timing is set before TDC.
1980 SC
71 Chevelle SS454
Old 05-23-2008, 01:13 PM
Free minder
Aurel's Avatar
On my SC, the 5deg mark on the pulley is after the the Z1 mark, clockwise. So that is past TDC, I think. Then, at higher rpm, the vacuum advance mechanism brings it about 30 degs before TDC.
So, I was wondering, with a different cam profile, if I should set my initial advance at a different value. The DC15 have 1.9-2.0 mm overlap at TDC, while the SC have 0.9-1.1 mm. Does it make a difference for ignition timing is my question.
Aurel
Old 05-23-2008, 01:51 PM
Wer bremst verliert
JohnJL's Avatar
Watch your pulley turn over again, it runs clockwise and those marks are BTDC. You should curve your distributor for each specific engine configuration for max results but depending on your application might be "good enough."
Search under my name and "ignition map" and you'll find a map for a very similar engine to yours. I've posted a map for a 3.0 with DC20 cams and EFI. I spent a lot of dyno time working on that ignition map, you're welcome to use that as a starting point.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-23-2008, 04:21 PM
Free minder
Aurel's Avatar
Okay I get it now. The 5deg mark is after Z1 mark, which means that it is reached before TDC turning clockwise. I got it running pretty well now. Just for confirmation, with the advance line plugged in, the Z1 mark should be seen shift clockwise with timing light, adding more advance to the initial 5 degrees, correct?
Aurel
Old 05-24-2008, 06:54 AM
