Used Oil Pump Opinion Sought
How foolish would I be to swap out my known good 2.7 oil pump for a used 90K SC pump from a fellow pelicanite? Thanks in advance for your 2c.
WARNING: Do not buy from Ron Kirby of Fort Thomas, KY (currently RRRacing1970).
Old 05-23-2008, 09:51 AM
dtw dtw is offline
GAFB
Same pump with an aluminum housing on the SC, if I'm not mistaken...assuming you have the 4-rib 2.7 pump (magnesium housing). Don't think there's any change in flow/pressure, but SC pumps are newer and seem to command a few more bucks in the used market. Having just faced this same decision, I kept my good 2.7 pump and sold the 3.0 pump I had on the shelf...
Several BMWs
Old 05-23-2008, 10:15 AM
What can I say? New pumps are pretty pricey. My motor was from a '74 911. I haven't yet cracked the case (or really looked in there even), but I gather the pump is the earlier 3 rib (and the case will need the oil-bypass mod to employ a later pump). My thought was that it's worth doing even if with a used SC pump.
The question was more about deciding if employing a used pump is foolish in general. I guess it's pretty common?
Old 05-23-2008, 10:35 AM
dtw dtw is offline
GAFB
Very common. Do your oil bypass mod and upgrade to a good used 4-rib 2.7 or 3.0 pump.
Several BMWs
Old 05-23-2008, 12:19 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The SC pump is a better choice in that the aluminum housing has a lower expansion coefficient. This means that the pump tolerances stay more consistent when things get hot.
Magnesium 908, 4 rib pumps are an improvement but the aluminum housing is the icing on the cake. Lower expansion rates are also the reason the turbo pump has a cast iron scavenge cell. There are ways to make these and turbo pump flow about 15% better.
Many shops will do this modification for you. Supertec is one.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-23-2008, 03:52 PM
jaybird840's Avatar
Send a message via Skype™ to jaybird840
Ok, so somebody dumb it down for me.... Will my 3 rib pump in good condition work OK on a 2.7RS build that won't see anything more than aggressive street driving? Oil bypass mod is being done on the case as we speak.... Thanks!
Jaybird
'75 914--slowly becoming a supercar
2.7RS spec rebuild in progress
Old 05-24-2008, 05:33 AM
Low oil pressure at idle is a chronic problem with mag case 2.7s. The larger pressure cell of the 4 rib pump is designed to create more flow at all rpm ranges to prevent low rpm oil pressure.
If you must use the old pump, get it flow modified and use cam feed line restricters.
Henry Schmidt
Ph: 760-728-3062
Old 05-24-2008, 10:10 AM
dtw dtw is offline
GAFB
What Henry said. But there's no reason to use a 3-rib pump when good used SC units are available for 200 or less.
You can make some of that $ back by selling your 3-rib pump to Roy @ MotorMeister.
Several BMWs
Old 05-24-2008, 10:19 AM
I'll take the first known good pump offered for 200 or less!
Old 05-24-2008, 11:45 AM
dtw dtw is offline
GAFB
There was one on the classifieds yesterday at that price.
Several BMWs
Old 05-24-2008, 12:40 PM
dion914-6's Avatar
Look around....bought a good used one on eBay last year for $110, but if you will give me 2 bills for it......
D
Dion
2002 Boxster S
1999 M3
Old 05-24-2008, 06:06 PM
